TwinTurbo.NET: Nissan 300ZX forum - output rod length
output rod length
doanh
on June 01, 2013 at 11:23 AM
so...what was the result?
posted by aliaZ
on June 01, 2013 at 05:48 AM
25 mm.. same as the old booster
weird brake problem - follow up
doanh
23:59:23 05/30/13
check your output rod length
aliaZ
00:26:14 05/31/13
Re: check your output rod length
doanh
07:53:43 05/31/13
doanh
08:34:30 05/31/13
doanh
21:37:30 05/31/13
aliaZ
05:48:27 06/01/13
output rod length
doanh
10:21:07 06/01/13
output rod length -
doanh
11:23:49 06/01/13
output rod length
doanh
15:53:16 06/01/13
did you even bother to look at the link I gave you?
aliaZ
06:56:15 06/02/13
the link
doanh
00:07:03 06/03/13
you measured it wrong
aliaZ
01:05:04 06/03/13
Re: you measured it wrong
doanh
00:37:23 06/06/13
Brake Booster check
doanh
17:01:34 05/31/13
Re: Brake Booster check
doanh
18:34:29 06/01/13
Brake Booster check
doanh
17:46:37 05/31/13
Re: weird brake problem - follow up
jaidieray
19:09:31 05/31/13
ABS actuators
doanh
21:39:13 05/31/13
Re: ABS actuators
doanh
18:32:00 06/01/13
brake lights stay on? bad brake booster?
doanh
20:54:40 06/01/13
